04-16-2009 08:23 AM
I keep getting the -1073807298 error when trying to control a linear actuator from Newport through a Newport SMC controller using some vi's supplied by Newport. I have traced the error message down to a VISA read function which generates the error.
However when I switch on execution highlighting there is suddenly no error. Then when I open the vi where the Visa read is located and switch on executon highlighting here, I get the error again! Peculiar, i must say.
I have tried both USB-RS232 and direct RS232 connections without any luck
I have also tried to add a VISA set IO buffer size and changed the size from 4096-200000 with no change.
Any other ideas to solve the problem? I could perhaps just ignore the error but that doesn't seem quite right.
I am using a vi example that can be found at ftp://download.newport.com/MotionControl/Current/MotionControllers/SMC100/Software/LabVIEW_Sample/
04-17-2009 07:12 AM
Do a search in the forum with the error code. You will get a couple of threads discussing the same problem. Post back if you still face issue.
Mathan
04-17-2009 07:54 AM
08-24-2009 06:10 AM
I had identical problem with "VISA: (Hex 0xBFFF003E) Could not perform operation because of I/O error". The solution for this issue in my case was to simply remove "VISA Shared Components" from the main list in "Add or Remove Programs".
WinXP
LabVIEW 7.1.1
NI VISA 4.5
Serial port on PC motherboard
02-01-2010 08:31 PM
