VB6, GPIB & USB multi-device commands
I am upgrading a legacy VB6 app, adding GPIB control using the GPIB-USB-HS device...what is the quickest way to get going?
I have tried out, with decent though slow luck,  some of the  "traditional commands"  & wonder if/how I might use some of the more modern multi-device commands?  Or perhaps I should be using something else entirely to miniumize the pain.  At this point we don't want to rewrite the entire VB6 app, just adding a bit of GPIB control.
Message Edited by AllGood on 02-01-2010 12:43 AM
(4,657 Views)
What kind of devices are you remotely controlling?
Did you check command syntax on the manuals?
Did you check the availability of drivers at vendor's website?
Regards
(4,642 Views)
I have the GPIB command list for my unit.  There are no drivers from the mfg.  The unit is connected to the pc via an GPIB==USB converter
My question is with VB6 & USB, can I use the 488.2 multi-device commands (or even something else)?  I tried the multi-commands, but VB does not recognize them.
Message Edited by AllGood on 02-01-2010 09:49 AM
(4,628 Views)
The USB would have no bearing on your code. You would be using the library that uses NI-488 or NI-VISA. NI-VISA is a higher-level protocol than NI-488 which allows you to change the communication protocol for a device without having to rewrite your code. You can take a look at the examples that ship with the respective libraries. For NI-488.2 the examples are in (on Windows) C:\Program Files\National Instruments\NI-488.2\Languages\Visual Basic. For NI-VISA the examples are in (for some reason) C:\Documents and Settings\All Users\Documents\National Instruments\NI-VISA\Examples\VB6.
(4,610 Views)
