Could somebody check my code? I got problem to reset and stop it
I am learning Labview and trying to use it to control Agilent 3646 power supply.
In this code, I can't reset the Agilent E3646 and stop the running code. it always gives me  " no responding" error from windowns, and I have to terminate by task manager....
thanks a lot for your help.
(3,346 Views)
 knew how to do it...
(3,339 Views)
Hey Gunking,
Just wanted to check with you on your last post, did the response mean that you have figured out how to get your code working? Thanks and have a great day!
Nicholas K
(3,323 Views)
yes...I did figured out what is the problem. thank you for your response.
(3,320 Views)
