GPIB-USB-HS installation problem Vista
Every time I plug in my GPIB-USB-HS device Windows Vista tries to install but cannot find the driver. I've downloaded & installed version 2.5 of NI-488 but everytime the GPIB-USB-HS is plugged in Windows prompts me for an installation CD. I've tried pointing the installer to the National Instruments directory on the hard drive, but no luck in finding the driver.
(3,648 Views)
Hello Jim,
Sorry to hear of your driver related issues, I was dealing with a simular problem a few weeks ago, which were solved by following the second of the following links.
1.       Explains which GPIB driver software you will require to run your GPIB-USB-HS with VISTA
http://joule.ni.com/nidu/cds/view/p/id/335/lang/en2
2.       Discusses the removal of unsupported NI software from Windows, prior to the installation of your new software. https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
Please let me know if the issues persist.
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,586 Views)
