Curseurs WaveSurfer 64Xs - TCP/IP
I am starting off the LV programming. Actually, I would like to improve/upgrade the driver that Lecroy made available to us regarding this oscilloscope.
I am using the example illustrated in the manual and advised for a use via GPIB (see Below)
However, I do not manage to transcribe it again with my lcwave elements (lcwrite, lcread)
"The following instruction positions the VREF and VDIF cursors at +3 DIV and -2 DIV respectively, using Trace F1 as a reference:
            CMD$=“F1:CRST VREF,3DIV,VDIF,-2DIV”:
            CALL IBWRT(SCOPE%,CMD$)
The following instruction positions the VREF and VDIF cursorsat +3 DIV and -2 DIV respectively, using Trace F1 as a reference:CMD$=“F1:CRST VREF,3DIV,VDIF,-2DIV”:CALL IBWRT(SCOPE%,CMD$)"
 Regards !
(3,163 Views)
And thank you for posting here.
Could you give us more details?
Which example do you use?
Which oscilloscope do you use?
Do you want to bring additional functionality to the driver VIs lcwave?
Could you also post the manual for this oscilloscope and explain where do you see the instructions that you join.
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(3,145 Views)
