I can't install NI-VISA on Centos 5.5
Hi all,
I can't install NI-VISA v.5.0.0.iso on Centos 5.5 distro. I have followed the README file and I have seen that this problem is solved into OpenSUSE disto. The error is
************************************ ERROR *************************************
* Kernel source does not appear to be installed for the 2.6.18-194.3.1.el5 kernel.
*    Installation of the kernel-source package for kernel 2.6.18-194.3.1.el5 is
*                   required to continue this installation.
I have installed also the kernel-source package as showed into following link http://wiki.centos.org/HowTos/I_need_the_Kernel_Source. The error is the same.
Could you please help me?
(4,427 Views)
Hi Scagno!
Unfortunately VISA driver is not compatible with CentOS.
What kind of device do you have to control with thos driver (usb, serial, gpib..) ?
Bye!
MarcoMar
National Instruments Italy
(4,415 Views)
Hi MarcoMar,
We are looking to control a spectrum analyzer remotely over an Ethernet connection - what are our options ? The unit is an Agilent N9340B
Bye
Scagno83
(4,406 Views)
Dear All,
We have completed the installation of NI-VISA-5.0.0 on CentOS 5.5. We have solved installing correct kernel-devel in our machine.
Thanks for your support.
Bye
scagno83
(4,357 Views)
hi,Scagno83: I can install NI-Visa4.4 in Labview8.6 on centos5.6, but I can't install visa5.0 on centos5.6, it says:
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: gcc 版本 4.1.2 20080704 (Red Hat 4.1.2-50)
* kernel compiled with: 4.1.2                                                 *
Have you tried visa5.0 on centos5.6?
(4,191 Views)
Hi lup,
I have updated 5.5 distro to 5.6. I have run updateNIDrivers utility as root. So I confirm you that NI-VISA 5.0 driver works also with CentOS 5.6.
Regards
scagno83
(4,174 Views)
