DAQ 1 sample (on demand) vs. continuous samples
I have a NI USB-6501 DAQ.  The device does not support acquiring continuous samples.  I need to continually poll the DAQ for signal changes.  I was thinking of putting the DAQ assist inside a loop, and just re-acquring 1 sample over and over.  Would this cause performance issues?  I'd like to run the loop about 1000 times per second.
(3,765 Views)
Accepted by Sam.Pearson
Refer to this benchmark [broken link removed; article no longer available]. Your results could vary greatly and there could be large amounts of jitter.
p.s. You posted to the wrong board. You should have posted to the Digital I/O board.
(3,764 Views)
