DIsconnect power realy
I am looking for an in-line relay that would interface between the 120V outlet and my test system.  The relay would act as a disconnect between power and test system.  The in-line relay would accept a digital signal that controls the status of the relay.  The in-line relay must not require any wiring, must be plug and play.
Kudos and Accepted as Solution are welcome!
(3,249 Views)
-          Please check these two measurement systems.
-          9481
-          9485
Regards
(3,225 Views)
