How to Load file from 4155B, execute it and save results to excel with Labview
Hi, I need a guidance in command pattern sending to 4155B by using Labview.
I would like to Load file from diskette on 4155B by using Labview. Firstly, I tried to write command by using MAX and found that the command I write to 4155B contain error message. I sent both GT 'P MYFILE" and :MMEM:LOAD:STAT 0, filename commands at each time to 4155B but failed. May I know what kind of command should I send to communication with the instrument?
Besides, I will need to execute the file content, should I send OUTPUT @Hp4155;"XE" command?
After execute, I need to save back the result to excel file.
Appreciate if someone can help. Thanks in advance for your kind help.
Yong
(3,551 Views)
Accepted by topic author SH_Yong
Besides, I will need to execute the file content, should I send @Output @Hp4155;"XE" command?
Yong
The SCPI commands are found in the instrument's manual.
(3,534 Views)
Hi nyc, thanks for your reply. I have tried to write few SPCI command to the instrument. They work well. Thanks for your kind help Smiley Happy
(3,524 Views)
