DMA Options with NI PXI to 3rd-party PCI Device with no DMA Controller
I need to pull data out of my 3rd-party PCI device at 22MB/sec.  The fastest I've been able to go using NI-VISA 5.4 in LabVIEW 2013 is 1.6MB/sec with the Move In 64 function.  There is no DMA controller on the 3rd-party device.  I was hoping to use the host's DMA controller and a VISA MEMACC object, but I stumbled across KnowledgeBase 3229I2RA: How Do NI PXI Controllers Support DMA (Direct Memory Access)?  The KB states, "Our PXI controllers only support the PCI specification, and therefore do not need a DMA controller on the motherboard."  If there is no DMA controller on the 3rd-party PCI device, are there any DMA options for my 3rd-party device on NI PXI controllers?
Thanks for your time and thoughts,
Steve K
(5,182 Views)
That's confusing. You say you have a have a pci device but talk about a pxi controller. Is the device actually pxi? Why use VISA? Doesn't the vendor provide a Windows driver? What does the vendor specify as a transfer rate? What is the make and model of the device?
(5,177 Views)
Thanks for your clarifying questions Dennis.  The device is cPCI.  I'm trying to automate it from an NI PXI controller in a cPCI chassis.  There is no Windows driver.  I realize it's not the standard setup, but it's all designed to work together via the PCI spec.
Steve K
(5,174 Views)
Accepted by Pie566942.0
There are currently no user-accessible PCI DMA controllers on NI PXI computers.
(5,068 Views)
