DPO
I'm using Labview 8.5 to acquire waveform from DPO7104 Oscilloscope.This oscilloscope has Windows system inside which is said it can be seen as a combination of a oscilloscope and a computer.My problems is I just can't connect the LabView with the oscilloscope device.The MAX shows a question mark on the device name while the device status is "VISA returned that device when finding resources,and MAX could use VISA to parse the resource name.MAX could not successfully open a VISA session to the device."Then I check the troubleshoot which is "the device may be missing some functionality.You may not experience any problems using the device if your application does not require the unavailable functionality."
I guess that maybe I need to get a capture card for the DPO7104 and I want to know whether it is or there are any other problems.
ALL in all,I want to know how can I make the MAX to identify the DPO7104.Can anyone help with that?
(3,642 Views)
Are you connected via GPIB, USB, Ethernet, other?
(3,639 Views)
via the GPIB
(3,633 Views)
via GPIB
(3,630 Views)
