How to connect 181 keithy nanovoltmeter via gpib-usb-hs using labview?
I am trying to connect 181 keithy nanovoltmeter via gpib-usb-hs. but while clicking on the data acquisition,on vi template, it desplays like "no supporting devices found". what may be the reason?
(3,157 Views)
Accepted by topic author saruajju15
You don't use data acquisition functions. You use VISA. See here.
(3,154 Views)
Thank u for your replay, it helped me a lot. But i can't view the video attached with the reply.
(3,122 Views)
