DSO5012A scope. IVI driver. Trigger source name in labview
Hello Unai,
       I am very happy to hear that it works well when you use the native IVI-C Specific driver that is NI-Supported.  One way of determining if a driver has an IVI-C wrapper is by looking at the Software Module.  Only IVI-COM drivers have the Prog ID field populated.  The Module Path field is used for IVI-C.  If both fields are populated, than the driver is most likely an IVI-COM driver with an IVI-C wrapper.
All of the NI-Supported IVI drivers available on IDNet are native IVI-C, so I recommend that you check there first for instrument drivers.
Cheers,
NathanT
Message 11 of 12
(1,162 Views)
NatthanT,  thaks for the information and the support!
I realized that most of the drivers that I am using are not native IVI-C drivers.
Best regards!!
Message 12 of 12
(1,159 Views)
