Data Acquisition
 I'm beginner in labview environment's trying to acquire some data of Ultra Wide Band(UWB) Radar using HP 8720B network analyzer and GPIB USB HS. I installed driver for GPIB USB , got VISA libraries too,and MAX show that device is installed and working properly. I don't know how to use the whole system so that I could record the data from my radar to process it .
(3,554 Views)
Hello Taran,
      I recommend that you use the Agilent 87XX Series LabVIEW Instrument Driver for your instrument.  The easiest way to install the driver is by using the Instrument Driver Finder through LabVIEW.  Try running some of the examples that are included with the driver and confirm that they work with your instrument.  If they don't work, than please consult the Instrument Driver Troubleshooting Guide.
Cheers,
NathanT
(3,535 Views)
