Data acquisition from Agilent's 54622A oscillocope
I want to increasing the data acquisition rate from Agilent's 54622A oscillocope to PC. I'm using labview.
How to achieve this/ using some extra external hardware ? At present I'm using GPIB-USB cable from NI (https://www.ni.com/en-us/shop/model/gpib-usb-hs.html).
Thanks.
(3,390 Views)
I'm not sure what you are asking here.  Are you simply looking to control the scope with LabVIEW using GPIB?  Or are you looking for a specific command?  Did you download LabVIEW drivers for this scope?
(3,380 Views)
Thanks for your response.
I already have the driver and can acquire signal from the oscilloscope. But at present the acquisition rate is very slow for my purpose.
I want a much higher acquisition rate. For this, is some extra hardware required ? This is my quesiton.
(3,359 Views)
