GPIB/TNT 182885E Drivers
We are trying to install a Plug N Play GPIB/TNT 182885E-01 Card on Windows 2000 NT. Windows does not have the driver. Are they available online?
(3,394 Views)
(3,392 Views)
Hi jim421,
All of our GPIB cards use some form of the 488.2 driver. Depending on how old the card is and what operating system you're using, what version you can use will change.
So I think the GPIB/TNT card you're referring to is this one (the page has both a PnP and the non-PnP version)? If that is the case, then you would likely need NI 488.2 Version 2.7.3.
Also, you might have already found this manual: Getting Started with Your AT-GPIB/TNT (PnP) and the GPIB Software for Windows. It could be useful for you going forward.
Good luck!
Ravi A.
National Instruments | Applications Engineer
(3,362 Views)
