Data acquisition from pci 8431/8 using labview
I am having an NI PCI 8431/8 RS422 Serial Card with 8 Channels. I want to read from all the 8 Channels in parallel. I am using a Intel Dual Core PC with Windows XP and LabVIEW 8.6. I need to read from the port every 10 ms. . I am having the following questions:
1. Should i use parallel while loops for reading, extracting, analyzing and displaying the data, for each channel?
2. Can i used timed while loops instead of while loop?
3. Is a queued state machine possible for this application?
4. Will the usage of 8 parallel loops consume my CPU usage?
5. Is there an architecture for this kind of applications?
(3,233 Views)
Firstly, wite all the channels with the respective commands. This can be performed in a single window of a sequence.
Then read from all the channels after a delay time. The delay occupies another sequence window.
Finally read from all the channels and save the values into an array.
This occupies the final sequence window.
Finally a delay also.
Keep all these inside a while loop so that it repeats itself.
Regards
Grugh
Regards
Grugh Mike
Success is Everything !!
(3,219 Views)
please don't mention that this should be done in a sequence structure. Use error wiring to ensure data flow sequencing
greetings from the Netherlands
(3,214 Views)
Yea sorry !!!
Regards
Grugh Mike
(3,213 Views)
