MAX shows the GPIB interface as question mark
We installed Keithley 2635 driver and uninstalled the NI 488.2, the MAX shows in the devices and interfaces a lot of yellow alerts, see attached figure. The computer still can talk to the device.  Can any one tell me why and is it normal?
Also, now, we are going to use lock-in SR 83, it needs NI.488.2, how can we use them two in one computer ?
Thanks a lot in advance.
Message Edited by deathelement on 02-24-2009 12:01 PM
Message 1 of 10
(4,396 Views)
Why on earth would you uninstall the NI driver? Why don't you remove the GPIB controller at the same time? The driver is necessary if you are using a GPIB controller from NI and removing it does not make any sense. A driver for an instrument is something completely separate.
In order to use two instruments, you just have to connect them. Daisy chain or star configuration will work.
There are numerous basic GPIB tutorials available on the Internet. I suggest you try googling for one before you do any more work withGPIB.
Message 2 of 10
(4,389 Views)
Thanks, and I uninstalled it buecause Keithley says so.
Anyway, I will try to learn more about GPIB.
Message 3 of 10
(4,382 Views)
I can't imagine why Keithley would tell you to uninstall a driver for a GPIB controller. The only reason they should tell you that is if you were using a controller from Keithley and not a 2635.
Message 4 of 10
(4,378 Views)
i have 2635a
i downloaded NI driver.
my problem is i can not do fixed source measurement by using decimal values.
for example i want to set bias as 0,2 volt.
but it is setting as 0 volt.
can anyone help me?
Message 5 of 10
(3,945 Views)
Don't use a comma as the decimal separator.
p.s. And in the future, please start a new thread instead of hijacking an old and unrelated one.
Message 6 of 10
(3,942 Views)
what should i use instead of comma
Message 7 of 10
(3,939 Views)
A period. Just like the manual tells you to use, probably.
Message 8 of 10
(3,928 Views)
thanks it was very helpful
i have another problem, now.
when i try to read datas from the buffer.
it is giving one time right datas then it is giving 1 respectively.
 do you have any idea?
Message 9 of 10
(3,923 Views)
Dear Khadir
Please attach the vi so that we can comment on what went wrong.
Regards
Grugh
Regards
Grugh Mike
Success is Everything !!
Message 10 of 10
(3,903 Views)
