Debugging intermittent Timeouts GPIB
Hi All,
I am at wit's end trying to debug an intermittent timeout in GPIB communications in a system involving a wafer prober and and Keithley 237 source-measure instrument. System is a basic Step-Measure-Step-Measure architecture where both instruments are VISA/GPIB controlled.
Measurement process involves thousands+ steps and each step can take in the 3-6 seconds range, making a single measurement process last a few hours.
Timeouts occur intermittently after minutes or hours of stepping.
Each instrument has it's own LV class and a wrapper class is used to time communication over the USB GPIB cable.
Any suggestions on how to attack this issue?
(4,877 Views)
What is the speed of the gpib bus. It defaults to a higher speed than the 237 can handle.
I suggest to set the speed to 2 microseconds.
greetings from the Netherlands
(4,833 Views)
