32 bit byte swap
I'm trying to read data from Agilent OSA that output the data in 32 bit number through GPIB interface.
if the bytes are numberd as 0, 1 , 2, and 3 - I need to swap 0 and 3, 1 and 2.
that is: to start with 0/1/2/3 and to end with 3/2/1/0.
can someone help how to do that for each 32 bits?
Message 1 of 8
(7,222 Views)
Can you give an example of the data message coming from the instrument?  My initial thought is to just use Unflatten From String with a U32 (or I32) as the data type and the Endianess set to Little Endian.
Message 2 of 8
(7,193 Views)
The data set is simply the trace of the OSA.
1001 numbers such as -45.26 for example.
Message 3 of 8
(7,191 Views)
I attach an image of my proposed solution?
I found split and joing function for high and low byts or word - so I split, swap and rejoin in reverse.
what do you think?
Message 4 of 8
(7,167 Views)
Ah, so it is just an array of SGL data coming from the instrument.  Here is what I propose
Message 5 of 8
(7,162 Views)
none of the above works.
I'm very high exponnets numbes (E+8).
Any suggestions?
Message 6 of 8
(6,972 Views)
Is that floating point constant that you show in your jpg a double or a single?
I can't see from the jpg but it makes a big difference in values.
greetings from the Netherlands
Message 7 of 8
(6,932 Views)
Let's clarify this a little more.  A SGL (Single Precision Floating Point) uses 32 bits to represent a number.  A DBL (Double Precision Floating Point) uses 64 bits.  So when you convert to your floating point, make sure you are using SGL, just like I did in my snippet earlier.
Message 8 of 8
(6,839 Views)
