I can't find the NI Device Loader in the Service menu
I am trying to detect intruments in NI-MAX, one connected by USB-DAQ and one connected by USB-Serial. Despite the USB-DAQ appearing in the Device Manager, it is not in NI-MAX. And while I can see the USB-Serial COM port, I can't communicate with the instrument. The help resource suggested that I make sure that the NI mDNS Responder Service and NI Device Loader were running. I found NImDNSRS running in the Services menu, but the NI Device Loader was no were to be found. I have found advice on how to turn it on, but I don't know what I need to install so that it is available.
(12,954 Views)
Accepted by topic author jbjz
It looks like you have not installed NI Device Drivers since The GPIB Enumerator service and a few others are missing too.  You can download the file from Here and Here
NOTE: the drivers finally got too large for one DVD and both are needed for a full install (part of why it ships on USB3.0 sticks now)
(12,914 Views)
Thanks so much! I thought that I had installed the necessary instrument drivers, but apparently I had less than a quarter of them. I am now able to communicate with my instrument.
(12,861 Views)
I'm having the same problem.
I'm upgrading a bunch of systems from Dev Suite 2012 to 2014.  NI Device Loader is not showing up in Windows Services for 2 machines; a laptop running WIN XP Pro 2022 SP3 and a desktop running Win 7 Ultimate.  The other systems are running Win 7 Pro.  I've uninstalled MAX as suggested by http://digital.ni.com/public.nsf/allkb/D1F1D3FC80E4FFDF86256B410059DE31 and reinstalled the drivers.  No change.
Currently the laptop has no hardware connected to it so the missing devices and remote systems are from a previous configuration.  But it still bothers me that NI Device Loader doesn't exist.
I've enclosed a PPT document showing particulars about the problem desktop.
Any suggestions?
(12,146 Views)
Hi faustina,
Have you run Part 1 and Part 2 of the NI Device Drivers that Jeff posted? Also, since this is an older thread, it would be a good idea to repost your question in a new thread to get more responses from the community.
Eric H.
Eric H.
Senior Applications Engineer - Product Analytics
Emerson T&M (NI)
(12,100 Views)
no, I downloaded from the driver DVD that came with Dev Suite 2014 DS1:  LabVIEW 2014 DS2 plus driver DVD dated Aug 2014
(12,095 Views)
