Delay between two write and read operation on serial port
I'm using a PC serial line connected with k-line interface. The effect is that for each character that i send, there is the eco in rx.
A typical operation is: -write a byte on port
-wait the eco on receiver buff.
-read 1 byte in the buffer
I need to implement this operation several time but the delay between each phase (write-wait-read) is greater than 5ms.
For my application is very injurious.
I think that this problem depends on the serial vi given with LabView (5.1).
How can i read and write serial line without using this vi module?
Are there anyone that has given this problem?
(3,972 Views)
Can you set your serial hardware receiver to trigger on one byte received or, though worse, disable your serial hardware fifo/buffer?
(3,972 Views)
Thanks for your answere.
I have disable serial fifo and now the comunication
works without any delay.
(3,972 Views)
how did you disable the serial fifo buffer. I am having a delay problem myself. However, the delay occurs when my program enters a 6th level nested sequence structure. The delay is random though. Sometimes there is no delay other times it can be 600us. I really need to get rid of the delay. Thanks for an help
(3,972 Views)
