ISA slot gpib card
I have a GPIB Card that is for ISA slot. It is from national instruments. But I donot know what is the version and which driver to use. Labview does not detect it, neither does windows 98 or XP
(3,294 Views)
First, check the board's name print on it. It is probably an AT-GPIB/TNT. It could also be a AT-GPIB, which are older.
You can then find the drive that supports this hardware in a given OS at:
http://www.ni.com/support/gpib/versions.htm
Follow the link of the driver version to download the driver.
Hope this helps.
DiegoF
National Instruments.
(3,294 Views)
