Devices and interfaces- Indentification unkown?
Hello All,
I have a question regarding the "Identification" value shown under the Devices and Interfaces section in MAX.  I'm using MAX version 4.7.4f0.  Here is the exact location of my question: MAX,Devices and Interfaces,Instrument x,Attributes,Indentification.
I have multiple devices installed, all devices except my Krohn-Hite 526 have the device info in the "Identification" section,
example: Agilent, 3240A .........
The Krohn-Hite has *IDN? yBy (?????)
I am not sure if it could be an installation issue?
See screen shot attachment
(4,342 Views)
Wrong image attachment Smiley Sad
(4,338 Views)
The correct image attachment! Smiley Happy
(4,335 Views)
Accepted by topic author BryanS
I needed to "Scan for Instruments' inside of MAX.  Interesting was that I still had full control over the unit in LV and TS??
(4,328 Views)
Just a side note for others that may come across an issue like this.  Not all devices support the standard ID query, especially older instruments that are not compliant with 488.2.  Take a look in the device manual and see what the proper command is for device identification.
(4,278 Views)
