Difficulty in Opening Visa Panel for Pickering PXI Matrix in MAX (Hex 0xBFFF0011 error observed)
Hello everyone,
I am having a Pickering LXI chassis 60-104-001 with PXI Matrix card 40-580-001 interfaced through LAN. I am able to detect them in NI MAX but unfortunately I am unable to open the VISA Test Panel for PXI cards. It throws an error ( VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.)
  • MAX 2023 Q4
  • VISA 2023 Q3
  • installed the VISA and IVI drivers for the card from Pickering.
Please find the attachment.
Any help Please.
Thank you in Advance.
Krit
(1,372 Views)
Hi, I'm having the same problems. Seems like having issue with NI-VISA driver? Did you solved it and how?
(1,006 Views)
Accepted by Krit112
Hello Toanlv_97,
Unfortunately Pickering LXI chassis 60-104-001 doesn´t support VISA, but you can use the IVI drivers for communication.
However make sure you install all the necessary drivers from the Pickering( PXI, LXI and IVI drivers)
Krit
(985 Views)
