Digital Oscilloscope Data acquisition using SCPI command
Hello folks,
I have a Digital OScilloscope RTO Rohde (https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_common_library/dl_manuals/gb_1/r/rto_1/rto2000...)
The remote control worked perfect and some command too. Moreover, I dont know how to transfer the data (curve/Trace) to my PC.
I want to reproduce the plot (result curve from Oscilloscope). Anyone has any idea to help? which should be a correct SCPI command?
How will be a correct procedure to do it? read or transfer the Column data.
(4,969 Views)
Any example script didn't help you?
For example, "Transferring Long Term Measurement Data" on page 1200
Certified LabVIEW Developer
GCentral
(4,936 Views)
Emboar, thanks for the comment. I tried it here//....but it doesn`t worked fine.
Same page, but before there is " Exporting Long Term Measurement Data to File".  One question. Whats the difference between " Exporting " and " Transferring " to long Term? I think,that exporting long term data file could be fine to me, right? So, I tried it also, but, I would like to know for instance at line " EXPort:MEASurement:NAME 'C:\Measurements\Meas1.csv'"  - This address should be in my Computer or in the Oscilloscope Folder directory?   thanks a lot,
(4,923 Views)
Well... I don't know the difference. I haven't used the instrument.
I just wanted to help you, read the manual you posted and gave a suggestion.
GCentral
(4,913 Views)
