Do i need any extra equipment for triggering​?
Dear all,
I have NI USB-6343 X Series Data Acquisition, I will collect data from loadcell, and according to the specific loadcell value, i will trigger a motor controller(which has also labview drivers), and tell motor controller to stop and go home position,
My questions are indicated below:
1-) Motor controller is connected to PC, DAQ is also connected to PC, but there is no direct connection btw the motor controller and DAQ, should i keep as it is? OR do i need to buy some equipment such as special cable?
2-) Motor is DC motor, but loadcell gives analog signal. So while triggering: Do i need to convert load cell's analog signal to digital signal?
3-) Do you have any labview samples smilar to this?
My all equipments are listed below:
Motor Controller= Newport SMC100CC Single-axis DC motor controller/driver
Motor Linear Stage= Newport MFA-CC Miniature Linear Stage DC motor
DAQ= NI USB-6343, X Series Data Acquisition
Loadcell = Transducer Techniques, GSO-100 (Tension&Compression)
Loadcell Signal Conditioner = Transducer Techniques STAND ALONE / BENCH TOP, 0 to ±10VDC OUTPUT
Thank you ,
Best Regards from Turkey..
(3,496 Views)
I forgot to ask the most important question,
Does every device triggerable? If not how do i understand that my motor controller could be triggered by DAQ ?
(3,493 Views)
Duplicate post.
(3,490 Views)
I dublicated it, because i wanted to share my subject with various Forum boards.
(3,486 Views)
Posting the same question to multiple boards is an irritating habit.
(3,480 Views)
Dear Dennis,
Am i getting on your nerves? u mad?
Thanks alot by though..
(3,478 Views)
