08-09-2012 12:56 AM
Hi there,
I am testing the PCI 6023E card but I found that it is always fail to setup a AO port for analog ouput, I am wonder if that card doesn't supprt any AO?
		08-09-2012
		07:05 AM
 - last edited on
		03-08-2024
		12:04 PM
 by
			migration-bot
If you go to the product page, you will see that the PCI-6023E does not have any analog outputs.
08-09-2012 07:34 AM
Is that any easy way to convert the digital output to analog one?
		08-09-2012
		08:29 AM
 - last edited on
		03-08-2024
		12:11 PM
 by
			migration-bot
A digital output will only put out a High level or a Low level (usually 5V and 0V respectively). I guess you could use a separate DAC (Digital to Ananlog Converter) chip. But that usually will involve some somewhat complex programming and line toggling. Plus you will need many Digital lines.
If you want to keep with PCI, I would probably go with something like the PCI-6010. Or there is the USB-6008 if USB is an acceptable bus.
