Does anyone know how to remove IVI drivers..?
I am trying to install hp34401a_LV61 'installer' and keep recieving an error about ivi traditional / third party drivers need to be uninstalled.....
Please HELP !!!
(3,534 Views)
HI,
Most likely you have the traditional driver for the hp34401a.
If that is the case, you need to remove the hp34401a folder located in the LabVIEW\instr.lib directory. Removing this folder should be enough to remove the traditional driver.
If you have a older version of an IVI driver, go to C:\VXIpnp\WinNT\hp34401a. In this directory there should be an uninstall executable.
Hope this helps.
DiegoF
(3,534 Views)
