Does anyone know the complete list of gpib-32.dll exports?
Upon doing a 'dump' of gpib-32.dll I found the following exports that I cannot find the function parameters for:
CopyrightString
RegisterGpibGloblsForThread
SetGpibStatusVariablesForThread
ThreadIbcnt
ThreadIbcntl
ThreadIberr
ThreadIbsta
UnregisterGpibGlobalsForThread
ibevent
ibeventx
iblock
iblockxA
iblockxW
ibrdkey
ibunlock
ibunlockx
ibwrtkey
If anyone has info about any of these functions, please reply. Thank you.
(3,841 Views)
Many of those functions are not useful to you because they are used internally by the driver. A few of the functions can be found here: http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/fd37c544505542f88625680400569e20?OpenDocument and here http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/78b4fe652de1f9c18625682d006ceaa7?OpenDocument.
Hope theis helps.
Best Regards,
Aaron K.
Application Engineer
National Instroments
(3,841 Views)
Ok - What I am trying to do is mask the gpib-32 driver with my own, and then pass the GPIB calls onto the 'real' NI gpib-32.dll
I have an old piece of software that calls the NI driver and passes a string that is instrument specific onto it. However, I have upgraded the instrument and now need to modify that string. I do not have access to change the dll that the old software calls, so I must intercept the call by creating a 'mock' driver that's sole purpose is to pass all commands onto the NI gpib driver (and for ibwrts, modify the string and then pass it onto the driver). I have been successful under the 16 bit platform. however, for 32 bit using the NI interactive program for debugging, I successfuly get a handle from my dll to the ni gpib dll a
nd get all the function handles. However, as soon as my dll returns control to the NI interactive window, I get a "Memory referenced at 0x0ef54.... failed to read location 0x0000000" type of error. That is why I was wondering if those other functions are manipulated by the NI interactive program. Thanks for any help.
(3,841 Views)
I have the same problem: Old test software & new instruments. I tried API Hooking but I was not able to make it work. Did you solve your problem ? If yes please let me know.
Dominique
(3,841 Views)
