Driver 2182A nanovoltimeter keithley
Recently, i downloaded the 2182A's driver for labview from the NI page. I tried to make the nanovoltimeter appears in the functions -> express-> input ->instr  drivers (on the block diagram) just like i did with the 622x driver, but i could not make it.Does anybody know what the problem is?
(2,614 Views)
Maybe not in the express vis (location can vary...)?
(If you have found them in your file system, you can place them wherever you want in the menu ...;)  )
Rebooted?
Greetings from Germany
Henrik
LV since v3.1
(2,556 Views)
It is not on the express VI indeed. Now, i'm just picking up the VI  i want in the "select VI" area.Thank you!
(2,538 Views)
