07-24-2019 01:25 PM
Recently, i downloaded the 2182A's driver for labview from the NI page. I tried to make the nanovoltimeter appears in the functions -> express-> input ->instr drivers (on the block diagram) just like i did with the 622x driver, but i could not make it.Does anybody know what the problem is?
07-29-2019 07:49 AM
Maybe not in the express vis (location can vary...)?
(If you have found them in your file system, you can place them wherever you want in the menu ...;) )
Rebooted?
08-01-2019 02:46 PM
It is not on the express VI indeed. Now, i'm just picking up the VI i want in the "select VI" area.Thank you!
