Driver for Agilent (HP) E364xA power supply
I would like to control an Agilent E364xA dual output power supply by using the RS232 interface from within a VI I am working on. The only driver I could find is for E3632A, any chance this will work?
According to the documentation the power supply is SCPI compatible, is there as standard driver for SCPI?
If there is no pre-canned version, what in the documentation am I looking for to figure out whta data I need to send to the power supply?
Help is much appreciated.
Robert
(4,403 Views)
Robert,
On our Website, I was able to locate an instrument driver listed for:
E3640A,E3641A,E3642A,E3644A
It is written for LabVIEW,LabWindows/CVI
You can find this at the following path:
ni.com>>Downloads>>Instrument Drivers>>Downloads>>Select HP and Power Supplies..>>Seek
It should be the last result. I believe this is what you are looking for.
Good Luck,
Chris Drymalla
Applications Engineer
(4,403 Views)
These drivers do not do much for the E3647A Dual Output power supply.
(4,403 Views)
