Drivers not loading on Windows XP for ENET-485.
I'm no dummy or I wouldnt have gotten this fare. Checking "device manager" and the "diagnostic utility" I cant seem to get my newly purchased NI-485 to work on my Windows XP machine for lack of recongnized drivers. I cant even fine the ".inf" file myself. Any ideas? Software package loaded just fine, several times.
(3,449 Views)
Did you add the serial ports using NI Ports? You have to map the Enet ports to COM #'s on the local system before they will show in the device manager or the diagnostic utility.
(3,449 Views)
Thanks for the kind reply. However I still have the problem, after a few weeks of hacking at I seem to understand what the problem is but I cant seem to fix it. I see it with the diagnostic utility, as it if fails identify the right ports, and I can see the ports assigned in the device manager, but the devices are failing to actually connect as a com port. Ie any programs cannot see the actual com port as the device mananger has them assigned. I've tried this on two different computers now,two different OS's same results. I'm convinced it's something I'm doing wrong on the set up.
(3,449 Views)
