ENET-485 lock up
Platform:  Window 2000 SP4, NI-Serial Version 3.0
Background:  Our application uses an ENET-485/4.  Ports 1-3 are used to talk with communications equipment, and port 4 is used as an ENET-485/4 self-test port.  Our application opens ports 1-3 and polls the equipment (writes a poll request, and then reads back the poll response).  Port 3 is polled every 10 msec, and either port 1 or port 2 is polled every 25 msec.  Every 2 seconds, port 4 is opened (CreateFile) and then closed (CloseHandle) in order to ensure that communications to the ENET-485/4 are OK.  Should the open operation on port 4 fail (e.g., due to ENET-485/4 power-off or network disconnect), our application enters an error recovery process whereby the open handles on ports 1-3 are closed (CloseHandle) in order to terminate the I/O operations.  Our application then continuously attempts to re-open all four ports.
The Problem:  This application has successfully run for many days at a time in this manner, but recently, after running for ~24 hours, the open request on port 4 failed with error code 1450 (ERROR_NO_SYSTEM_RESOURCES).  As a result, the error recovery process described above was entered.  Each attempt to open any port resulted in error code 1450.  During this time, the port LEDs on the ENET-485/4 where not lit.  Running the NI Serial diagnostic utility was unsuccessful.  Perfmon was being run to record a counter log, and activity on the NiSerE_U process, which had been running at about 1.0-2.5 % of the processor, dropped to 0 %.  Power cycling the ENET-485/4 cleared up the problem, and the application error recovery process was then able to successfully reconnect to all ports.  The NiSerE_U process returned to its 1.0-2.5 %.  The system has been running successfully since then for three days.
It appears to me that the ENET-485/4 device may have locked up.  Has anyone seen such an occurrence?  Thanks for any help.
(3,430 Views)
See also thread "NiSerE_U.exe - Application Error" (http://forums.ni.com/ni/board/message?board.id=140&message.id=18496)
(3,395 Views)
