NiSerE_U.exe - Application Error
Platform:  Window 2000 SP4, NI-Serial Version 3.0
I received an Application Error message for NiSerE_U.exe.  Here is the entry from the system event log:
Event Type: Information
Event Source: Application Popup
Event Category: None
Event ID: 26
Date:  7/31/2006
Time:  15:40:37
User:  N/A
Computer: PTSA
Description:
Application popup: NiSerE_U.exe - Application Error : The instruction at "0x77f8206b" referenced memory at "0x00000014". The memory could not be "read".
Click on OK to terminate the program
Click on CANCEL to debug the program
Any ideas?
(3,422 Views)
Hi cme12345,
Where does this error occur?  Does it happen consistently?
Chris R.
(3,409 Views)
Our application uses an ENET-485/4.  Ports 1-3 are used to talk with communications equipment, and port 4 is used as an ENET-485/4 self-test port.  Our application opens ports 1-3 and polls the equipment (writes a poll request, and then reads back the poll response).  Port 3 is polled every 10 msec, and either port 1 or port 2 is polled every 25 msec.  Every 2 seconds, port 4 is opened (CreateFile) and then closed (CloseHandle) in order to ensure that communications to the ENET-485/4 are OK.  Should the open operation on port 4 fail (e.g., due to ENET-485/4 power-off or network disconnect), our application enters an error recovery process whereby the open handles on ports 1-3 are closed (CloseHandle) in order to terminate the I/O operations.  Our application then continuously attempts to re-open all four ports.
This application has successfully run for many days at a time in this manner, but occassionally, the open request on port 4 fails with error code 1450 (ERROR_NO_SYSTEM_RESOURCES).  As a result, the error recovery process described above is entered.  Each attempt to open any port results in error code 1450.  During this time, the port LEDs on the ENET-485/4 are not lit.  Running the NI Serial diagnostic utility is unsuccessful.
This popup appeared after one of these apparent ENET-485/4 lock ups.
The apparent ENET-485/4 lock up is described in thread http://forums.ni.com/ni/board/message?board.id=140&message.id=18253.
(3,390 Views)
