Error -1073807202 at simple loopback test with serial port COM1
I have tried to make a loopback test with the serial port COM1. With hyperterminal it works. An error (-1073807202) occoures at Configure_Serial_Port.vi. I have tested the communication with different resource names. I have tried other serial vi's. (e.g. Find_Serial_Port.vi). It is always the same error at Configure_Serial_Port.vi. My System W-Me, Labview7.0.
Know somebody about this error?
(4,658 Views)
The error indicate that the VISA library is not installed. Check this little knowledge base article: How Do I Resolve VISA Error -1073807202 (0xBFFF009E)?.
In the article you'll find a link to the driver download page.
DiegoF
National Instruments.
(4,657 Views)
Hiii
I'm also getting the same type of error but  even after following your previous link and installing the run time engine and the drivers...i'm facing exactly the  same error...
please guide me in rectifying the error and establishing the connection
(4,286 Views)
Are you also getting the error at the VISA Configure Serial Port? Could you possibly post an NI-Spy capture showing when this error occurs as well as a screenshot of your LabVIEW code? Thanks!
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(4,271 Views)
