Error -1073807202 occurred at Property Node (arg 1) in MB Serial Init.vi->MB Serial Example Master.vi
Hello , ni engineers.
I am working on MODBUS using RS-485.
I Downloaded the Library from https://www.ni.com/en/support/downloads/tools-network/download.modbus-master.html
After Installing the library , I tryed the MB Serial Example Master.vi .................but when I run it this error message appeares.
But when I run MB Serial Example Salve.vi   .................... It works fine.
I wondered what is the problem.
Thanks a lot for help.
Abdo.
(4,836 Views)
Hi Abdo,
What version of LabVIEW and NI-VISA are installed on your machine? Upgrading the VISA driver might solve your issue - refer to this link to install the latest compatible version: https://www.ni.com/en/support/documentation/compatibility/16/ni-visa-and-labview-version-compatibili...
You can also download a more recent, updated MODBUS library from https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019 and see if you encounter the same errors
Xavier
(4,814 Views)
