Framing error when I'm using a serial port.
I am developing some device to measure 3 axis movements.
This device transfers the data to the PC using UART (RS232).
I got the data in Hyperterminal but couldn't in LabVIEW.
The weirdest thing is that I can get the data in NI MAX like the
following picture. But I try to do the same job in LabVIEW there
is always error message like the second picture.
How can I solve this problem. I have searched through articles
about framing error using googling but I didn't find the appropriate
answer.
I'd like to thank you in advance.
(6,026 Views)
Almost always the reason I have seen a framing error is a baud rate mismatch.  Make sure all of your settings are correct.
(6,023 Views)
Of course, I double check the baud rate.
(6,019 Views)
You have neither shown the serial settings in MAX or in LabVIEW.
(6,002 Views)
