Error -1073807202 occurred at Property Node (rag 1) in VISA Configure Serial Port (Instr).vi->Indus.Auto.vi
halo,
I'm an engineering student dong my project based on LabVIEW. BUt when I try to run my VI it shows an error as following
Error -1073807202 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->Indus.Auto.vi
Possible reason(s):
LabVIEW: (Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded. This is usually due to a required driver not being installed on the system.
what can i do to correct this error..???
(4,101 Views)
Install the driver like the message says. Did you do a search for that error code?
(4,095 Views)
