link error while using IVI-C API, visual c++ express 2008, x64 platform
Hi there, I am trying to control the power supply via IVI-C API.
To get started, I followed the tutorial given by IVI foundation. (http://www.ivifoundation.org/downloads/IVI%20GSG%202012/IVI%20GSG%20C++%20MAR2012.pdf)
I followed the steps given by the tutorial, and could compile and build the application on win32 platform.
However, when building the same project on x64 platform, I kept receiving these errors:
error LNK2001: unresolved external symbol TQLP_InitWithOptions.
May you please tell me whether I could build the IVI API based application on x64 platform? If yes, how to solve this problem?
I have been spending lots of time in solving this link error problem. Any tips or help would be deeply appreciated.
Many thanks in advance for your help.
(3,824 Views)
Hi jwsun,
Which IVI-C driver are you using? If the IVI-C driver has a .lib file (I guess it should be TQLP.lib) under "C:\Program Files\IVI Foundation\IVI\Lib_x64\msc\", please make sure if this lib has already been added into the Link input path.
(3,818 Views)
Hi, Charles.Tac,
Thanks for your reply. 😃
I am using the IVI-C driver given by TTi (QL_IVI Driver-v1.6.0), and yes it is TQLP.lib. I have also added into the input of the linker.
One thing I forgot to mention is that I am using 64bits Win 7. Thus following the instruction given by the tutorial, the lib is supposed to be C:\Program Files(x86)\IVI  Foundation\IVI\Lib\msc\. For this path, I could find the TQLP.lib.
However, for the path you mentioned, I could not find the TQLP.lib.
So, which path should I add into the additional lib directories for the linker?
Thank you again for your kind assistance 😃
@Charles.Tac wrote:
Hi jwsun,
(3,817 Views)
Hi jwsun,
There should be two seperate lib file for x86 and x64. Could you make sure if you are using the correct lib in linker?
Please open a Visual Studio Command Prompt and type "dumpbin /HEADERS xxx.lib >> a.txt". Search the string "FILE HEADER VALUES" in a.txt, you could find the OS platform the lib support.
Wish that could help.
(3,809 Views)
