Error -1073807298 when communicating via COM port
I'm using Labview to acquire data from an IMU (Inertial Measurement Unit) via Bluetooth (with a USB Bluetooth connector). To do so, i use the COM 5 serial port and i'm able to read data from the IMU, by doing:
VISA configure serial port > VISA open > VISA read
The thing is when i try to write commands to port i get the error message -1073807298.
I used MAX to check the status of COM 5 and it is showing:
"VISA returned this device when finding resources, and MAX could use VISA to parse the resource name.  The resource is busy, so MAX could not successfully open a VISA session to the device."
How can i write bytes to port? Can anyone help with that?
PS: I'm still an amateur using Labview, so you will have to excuse me if a seem silly with this question.
(4,671 Views)
The port is probably in use by another application. Maybe some bluetooth stuff
greetings from the Netherlands
(4,663 Views)
Sorry for my late response....until now i had something in hands and i didn't have much time so review this problem...
So, i did more tests and this error continues....i try to use simple things just to try to comunicate with my device.
Using MAX and VISA test panel i can read data that is continously sent from my device. When i try to write a comand to the device this error occurs at VISA Write. It has something to do with the string i'm writing?
I really would appreciate if someone could help me...this is really killing me...
(4,546 Views)
look in the msg below. KC has solved this same erro, only he has it displayed in hex.
http://forums.ni.com/ni/board/message?board.id=140&message.id=34995#M34995
(4,539 Views)
