Return Status BFFF003E with visa serial write
Visa says connection ok but gives a return status of BFFF003E and will not return OK after AT command
(4,612 Views)
Do you have handshake enabled or is the serial connection sending CTS?
greetings from the Netherlands
(4,607 Views)
I got this error with a USB serial port. I solved this using the buffer function for this serial connection.
(4,599 Views)
This KB could be helpful.
Peter Flores
(4,577 Views)
