Error-For loop
I want to perform a frequency-sweep with "Agilent 33210A". I know that this device has the capability to do the sweep automatically, but I will use this program for other signal processing stuff.  I've written the program, but when I connect the "reset.vi" to the loop, I face the error "You have connected two terminals of different types". Should I use a data-type converter or something like that? The device has been installed correctely, because I can run the LV examples without error.
I have attached the file.
Does anyone know what is the reason that I cannot connect to "close.vi"?
In advance, thanks for your help.
Petar
(5,295 Views)
You just need to disable auto-indexing out of the for loop with a right click on the exit terminal. Have you taken any of the free LabVIEW tutorials? This is a basic default property.
(5,291 Views)
Actually, you really should replace the tunnel with a shift register.  The input shift register should be instead of the input tunnel.  Why?  If you accidentally wire in a 0 for the N, your reference will be lost when using tunnels (loop runs 0 times, therefore you get the default values out of the tunnels).  By using a shift register, you state what the value will be, even if the loop does not run.
(5,278 Views)
Thanks for all your helpful replies.
(5,243 Views)
