GPIB-RS232 lock up in c-mode
I have a simple driver talking to a GPIB device in c-mode.
This is working.
I am testing what happens in fault conditions.
If I power down the GPIB device and send a character on the RS232 I get the the following LED pattern:
RDY - Red
LSTN Green
ATN Yellow
FULL Yellow
BUSY Yellow
The only way out of this condition is to cycle the power on the GPIB-RS232
How do I make my application more robust?
(3,264 Views)
I ran into the same problem.
C-mode is not robust.
You have to change it to S-mode and program in S-mode to prevent it from locking up.
Its a pain since S-mode is more complicated and has it's own special syntax but its the only way I've found around it and it doesn't lock-up.
(3,014 Views)
