Error VISA: (BFFF006C) and (BFF006B)
Hello Tajana,
I already tried what is said in the link. That worked only for a moment. I unchecked the FIFO option but it worked only for a moment. I lowered the communication speed too, both to receive and to transmit, but I gor any result.
Strange thing is that when I disconnect the communication cable, Labview throws the same error.
Pleace help me, I am very worried, I must have it ok.
Best regards
Message 11 of 29
(2,152 Views)
could you please post your VI from the jpg-Picture, which you posted in your first message?
Best wishes
Tatjana
Message 12 of 29
(2,136 Views)
Dear Mr. Deutschrich,
I have two suggestions for you.
The first is (see in picture), please put "property node" instead of a constant (you have constant=9 in your picture).
The second and more important is the time (see also in picture).
Your Baud-rate: 57600, but you just wait constant="2" at "Wait until next ms multiple" (also just 2 ms). "2" is too short.
Rise your time up to constant="100" and your VI will work without problems.
I hope those suggestions will help you.
Best regard,
Tatjana
Message 13 of 29
(2,123 Views)
Dear Mrs. Tatjana,
I will test your suggestions in my program. I hope too your suggestions help me because I am already very worried.
Thank you and I let you know later if it help me,
Best Regards,
Ricardo.
Message 14 of 29
(2,115 Views)
Dear Mrs. Tatjana,
Ich tested what you said and It works with the same problem. I don't now what it's. I tested too with the MAX of LabVIEW and I receive the same error warning,"hex 0xBFFF006C".
Pleace, do you know what can be?,
Best Regards,
Ricardo,.
Message 15 of 29
(2,103 Views)
Dear Ricardo,
could you send me your VI, so that I can reproduce the failure?
I need just the past with the serial communication.
Tatjana
Message 16 of 29
(2,098 Views)
Here is the VI of my program.
Message 17 of 29
(2,095 Views)
Dear Mrs. Tatjana,
Here I attach too a small program that I am testing too and I receive the same error. I say again I receive the problem BFFF006C in the MAX too.
Best Regards,
Ricardo.
Message 18 of 29
(2,092 Views)
Pleace any Idea?
Message 19 of 29
(2,078 Views)
Hi Ricardo,
I find it strange that you get both errors.
Can you try to test the HW with Hypertermial. Connect pin 2 and 3 of your COM port. You should see what you are typing in Hyperterminal. Remove the 2-3 connection to be sure that it is running over the port.
Kees
Message 20 of 29
(2,066 Views)
