Error framing when communication Labview with Pic.
Dear All.
when I communication Labview with Pic, sometime the error occur: Error -1073807253 occurred at VISA Read in RS232.vi
Please, help me. Thanks!
(4,789 Views)
That could be any number of things.  Most common are serial port settings being mismatched.  Make sure the PIC and the computer have the same baud rate, start and stop bits, handshaking, etc.  It might also be a good idea to watch the serial waveforms on a scope and watch for anything weird happening when you get the error.
(4,762 Views)
Just checking the 8-Ball's calibration
~~~~Oh magic 8-Ball.  Is the OP trying to run some high baud rate in a noisy environment with a long, poorly shielded cable and no ferrite?~~~~
"It is likely."
(We'll see if the device gets a new cal sticker for 2014)
(4,748 Views)
