Error occurs when using the LeCroy Waverunner driver.
Hi
I downloaded a Lecroy Waverunner driver in Instrument Driver Network and installed it. However, when I used it in block diagram. An error message "lcltxxxx_32.DLL is not a 32-bit DLL" appeared. What's the matter with that?
Bill.
(3,231 Views)
Hello Bill,
It sounds like you have the wrong IVI engine installed. The current LeCroy Waverunner software on the website requires the 1.83 IVI Engine and NI-VISA 2.5 or later. If you have old versions of the IVI engine and/or NI-VISA, remember to delete the old versions before reinstalling.
Ray Kong
(3,231 Views)
