Error trying to update via VISA Driver Wizard
After doing a new install of LabView 2012 SP1 on a HP EliteBook, I ran MAX and was not able to see any of the USB devices connected despite having all the IVI drivers loaded beforehand. Upon running NI-VISA Driver Wizard, the program did recognize all of the USB equipment. I tried to install the drivers throught that but got an error message instead. Please see attachment.
What step am I missing here?
Message 1 of 12
(5,409 Views)
The driver wizard has absolutely nothing to do with IVI. What sort of USB equipment are you talking about.
Message 2 of 12
(5,406 Views)
I have several pieces of equipment via USB, the others are via GPIB. There is a GPIB to USB converter that MAX does detect. It is only the USB equipment that it does not see.
Here are the USB ones:
an Agilent U2653A switch
a Silab debug adaptor
a Xilinx platform cable unit
Do you have any suggestions?
Charly
Message 3 of 12
(5,382 Views)
Install NI-VISA, the IVI Compliance Package, the IVI-COM drivers, and all USB drivers from the vendors. These could be for serial or USBTMC connections.
Message 4 of 12
(5,379 Views)
I do have NI-VISA 5.1 installed. How do you check if it is the IVI compliance package? What's the difference? Also, where do I download the IVI-COM drivers? As far as the USB drivers from the vendors, I have downloaded the Xilinx ISE labtools and Agilent IVI drivers for the switch. I do have Agilent's Connection Expert loaded too. It sees the USB0 but no devices recognized branching out from that. Thoughts?
Message 5 of 12
(5,376 Views)
I just checked, I did install the IVI compliance package 4.5. This doesn't change the fact MAX still doesn't see the equipment. I even disabled, the Aglient VISA option. Do you have any other suggestions? Thanks.
Message 6 of 12
(5,372 Views)
Did you uninstall the files created by the driver wizard? Did you install the Agilent I/O Library? Were the instrument detected on a different pc?
Message 7 of 12
(5,360 Views)
I couldn't install via driver wizard, that was the problem. The driver wizard see the devices connected via USB, but that error message popped up (see original post for attachment). I did install Agilent I/O Library 13.1 version.
These pieces of equipments was recognized by a desktop previously until a power outage undid that that. At that point, these same equipment were requested to be used w/ a laptop instead. So never really did fix why the equipment was able to be detected by the desktop workstation again.
Sounds like you have an idea what the problem is?
Message 8 of 12
(5,356 Views)
At this point, I don't really know what you did. It sounds like you actually ran the wizard. That was a huge mistake. You have to actually delete the files you created or go back to a system restore point.
Message 9 of 12
(5,352 Views)
Long story short, I had to jump ship from a previous desktop computer setup to a newer laptop w/ same setup. So I had to load all the NI Developer suite stuff as well as all the accompanying drivers. I did have some security settings messing up the download process, but that is another story. Suffice to say, I thought after doing all that loading, then ran MAX, the equipment attached would show up like clockwork. No such luck. Unless there is a list of what do first available, this is what I did:
a. deactive security
b. load NI Developer Suite
c. update software
d. load drivers
e. connect equipment
f. check for communication
So it's at f, that I can't do.
Huh. Uninstall or delete the inf and ini files that was created by the driver wizard then? When the files were somewhat generated but that error about not installing successfully because I don't have the right access doesn't make any since. I guess it is worth a shot to delete those files generated.
BTW, do you have a number I can chat with you about this? Probably will be better than waiting for a post from each end? If you don't mind that is. Thanks again.
Message 10 of 12
(5,348 Views)
