 cdux
			cdux
			01-24-2014 07:35 PM
After doing a new install of LabView 2012 SP1 on a HP EliteBook, I ran MAX and was not able to see any of the USB devices connected despite having all the IVI drivers loaded beforehand. Upon running NI-VISA Driver Wizard, the program did recognize all of the USB equipment. I tried to install the drivers throught that but got an error message instead. Please see attachment.
What step am I missing here?
 Dennis_Knutson
			Dennis_Knutson
			01-24-2014 08:06 PM
01-25-2014 05:09 PM
I have several pieces of equipment via USB, the others are via GPIB. There is a GPIB to USB converter that MAX does detect. It is only the USB equipment that it does not see.
Here are the USB ones:
an Agilent U2653A switch
a Silab debug adaptor
a Xilinx platform cable unit
Do you have any suggestions?
Charly
 Dennis_Knutson
			Dennis_Knutson
			01-25-2014 05:18 PM
01-25-2014 05:34 PM
I do have NI-VISA 5.1 installed. How do you check if it is the IVI compliance package? What's the difference? Also, where do I download the IVI-COM drivers? As far as the USB drivers from the vendors, I have downloaded the Xilinx ISE labtools and Agilent IVI drivers for the switch. I do have Agilent's Connection Expert loaded too. It sees the USB0 but no devices recognized branching out from that. Thoughts?
01-25-2014 05:44 PM
I just checked, I did install the IVI compliance package 4.5. This doesn't change the fact MAX still doesn't see the equipment. I even disabled, the Aglient VISA option. Do you have any other suggestions? Thanks.
 Dennis_Knutson
			Dennis_Knutson
			01-25-2014 06:14 PM
01-25-2014 06:25 PM
I couldn't install via driver wizard, that was the problem. The driver wizard see the devices connected via USB, but that error message popped up (see original post for attachment). I did install Agilent I/O Library 13.1 version.
These pieces of equipments was recognized by a desktop previously until a power outage undid that that. At that point, these same equipment were requested to be used w/ a laptop instead. So never really did fix why the equipment was able to be detected by the desktop workstation again.
Sounds like you have an idea what the problem is?
 Dennis_Knutson
			Dennis_Knutson
			01-25-2014 06:32 PM
01-25-2014 06:45 PM
Long story short, I had to jump ship from a previous desktop computer setup to a newer laptop w/ same setup. So I had to load all the NI Developer suite stuff as well as all the accompanying drivers. I did have some security settings messing up the download process, but that is another story. Suffice to say, I thought after doing all that loading, then ran MAX, the equipment attached would show up like clockwork. No such luck. Unless there is a list of what do first available, this is what I did:
a. deactive security
b. load NI Developer Suite
c. update software
d. load drivers
e. connect equipment
f. check for communication
So it's at f, that I can't do.
Huh. Uninstall or delete the inf and ini files that was created by the driver wizard then? When the files were somewhat generated but that error about not installing successfully because I don't have the right access doesn't make any since. I guess it is worth a shot to delete those files generated.
BTW, do you have a number I can chat with you about this? Probably will be better than waiting for a post from each end? If you don't mind that is. Thanks again.
